configure ospf vlan neighbor add
configure ospf vlan vlan-name neighbor add ip-address
Description
Configures the IP address of a point-to-point neighbor.
Syntax Description
vlan-name Specifies a VLAN name.
ip-address Specifies an IP address.
Default
N/A.
Usage Guidelines
None.
The following command configures the IP address of a point-to-point neighbor:
configure ospf vlan accounting neighbor add 10.0.0.1
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
